Suhr Riot
Started by eniacmike, September 10, 2010, 07:34:00 AM
eniacmike
should be pretty straight forward, but I would appreciate a pcb some sweet madbean instructions for this high gainer.
-mike
Okay, yeah...I have a PCB done for it via FSB. The "Uproar". There are a few adjustments that need to be made, but I could make this available here.
eniacmike
man I need to bite the bullet and learn to etch my own boards.
-mike
maysink
[nothing to see here]
-e
Haberdasher
Etching your own is fun and satisfying.  You should try it.  I'm finally starting to get my technique down, but it takes a few tries.  I've gone through some material experimenting, you know- trial & error- so be sure to buy extra.
Here's my latest.
[attachment deleted by admin]
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
maysink
You got a tutorial to recommend?
-e
Haberdasher
Quote from: maysink on September 10, 2010, 06:24:02 PM
I don't really....my method is really a combination of different methods I've found around the internet.  I use one thing from here, one thing from there, into a method that seems to work for me- with the particular kind of paper I use and my laminator.  I do NOT iron.
I think madbean is supposed to be making a tut about this, and I know he does it differently than I do it.  I suspect his method is probably a lot more tried & true than mine.  I'm just now starting to get results I'm proud of, but not every time.  It really takes a lot of trial & error.
Of course, I will tell you what I do if you want to know, but not everyone is going to want to go out & buy a laminator.
HM
brian when you believe you can have ready Uproar??
I think within a few days. I'm pretty caught up on things which means I will have time to do fun stuff like a new project. Actually, I could possibly have TWO new projects by the weekend.
HM
Thanks brian I hope very excited this pedal is very close to being like .-
eniacmike
I have a few questions about the uproar project. it says d2 is 1234a? is that a mistake. I am guess it is supposed to be 1n34a?
d6 is 1n400x does that mean 1n4001 will work? I am guessing I should socket this clipping section.
IC's are JRC4580 does anybody have a source for these? I looked on smallbear, mouser, and jameco and it didn't turn up. I guess I could sub any opamp but I don't know if this is a particular mojo part. When I google it alot of posts on hi-fi websites and soundcard websites about that opamp.
I am going to put in an order for some parts and give this one a go this week.
Haberdasher
Mike-
*JRC = NJM*
http://www.mouser.com/Semiconductors/Amplifier-ICs/Op-Amps/_/N-4h00g?P=1z0yz4q&Keyword=NJM4580&FS=True
I don't know the difference between the NJM4580d and the NJM4580dd though.
B_of_H
I think i'd be up for one of these at least, I built it on perfboard but I think i'd like to give it another shot as I don't think it came out right.
r4ndy
Any update on this one? I did not see anything in the release schedule. I am looking to order a few pcbs at once and would like one of these as well.
Thanks
Ang3lus
