Current Lover: No Effect
Started by eldanko, February 26, 2012, 07:00:43 PM
You're not getting any varied pins at all now? That means both have locked up.
Check the pin out of your 2N5087, it may be worth pulling it and trying higher gain transistors along with other diodes, this section is infuriatingly picky.
D1 substitute is fine but try a 1N914 in D2, the higher capacitance of the 1N4007 diode seems to be the cause of issues in that section.
eldanko
I swapped a 1N914 into D2, no perceivable change. What transistor would you recommend for Q2?  Pinout on my 2N5087 is E-B-C.
Does the 2N5087 match the board though? Have you put it in the right way... there are different brands with different pin outs sooo...
A 2N5087 is fine, just depends which one.
eldanko
The 2N5087 has the pinout actually printed on it (which is nice), and I double checked the orientation with the schematic and it does appear to be in there correctly.  I swapped it with another 2N5087 I had and perceived no change.
Is there anything else I should try before attempting to swap out D1 as well? That little bugger is going to be near impossible to get to...
Quote from: eldanko on March 28, 2012, 10:59:10 PM
D1 shouldn't need changing.
So... you're sure all the values you're using are correct... you've swapped the chips... you've swapped the diode and transistor.
Here's some working voltages Lacesensor posted
LM324
1-4.6
2-4.6
3-4.2
4-9.2
5-1.4 - 2.0 ish
6- varies
7- varies
8-jumps 0.6 up to 7.5 and back
9-4.2
10-varies
11-0
12-4.2
13-4.3
14-varies
LM311
1-0
2-varies
3-varies
4-0
5-9.2
6-9.3
7-varies
8-9.2
eldanko
Here's what I'm getting now:
LM324
1-4.7
2-4.7
3-4.6
4-9.4
5-1.0-2.0 ish
6- 1.1-2.0
7- varies
8-jumps 0.6 up to 8.1 and back
9-4.4
10-varies
11-0
12-4.4
13-4.4
14-varies
LM311
1-0
2-varies
3-varies
4-0
5-9.4
6-9.4
7-varies btwn 7.0 and 9.0
8-9.4
So... Not locked up anymore?
I double checked all resistor values in that area and found no problems...
Lookin' better! Now try playing with that cap value and readjusting the clock and bias.
eldanko
I just tried a series of values ranging from 10pF to 220pF in C18... still can only get a very intermittent flange, and that's generally only when I bump up the Rate a bit...
eldanko
I've been trying to bias at 9V and 12V.  Would bumping to 15V help at all?
Quote from: eldanko on March 29, 2012, 03:42:40 PM
I doubt it, it shouldn't be that tricky to bias, while clock and bias do interact a bit it's not massive.
This has got me a bit stumped... can you 'manually' flange it in filter matrix mode?
If so we can either rule out or pin point it to the clock/LFO
eldanko
Yes, this is easily the most vexing debug I've ever had to deal with.  I'm learning a lot, but I sure wish I could get the blasted thing to function.
No luck manually flanging, after twiddling the trimpots and controls several different ways.
Quote from: eldanko on March 30, 2012, 03:03:35 PM
Hmm.. might have spotted something, check the values of R20/21/25/26 C16 and make sure the joints are good.
I'm wondering if it's the Filter matrix switch itself or the opamp feeding the 311.
TNblueshawk
Hey ED, as I prepare for this build, did you ever find the issue?
John
eldanko
Sadly.... no.
This thing has been the "Moby Dick" of my pedal building experience thus far.
Scruffie generously offered to take a look at it, but after calculating the costs of shipping it across the Atlantic and back, I think I may just take another hack at it with a new board since the more expensive parts are socketed anyway.
I'll certainly keep this thread updated if there's any new developments!  It breaks my heart, as the enclosure I have planned for this one is pretty freakin badass.
TNblueshawk
Bummer man. I'll build mine in your honor  :)
John
