Sea Urchin problem..
Started by ckim715, February 25, 2012, 10:36:07 PM
ckim715
So I have an odd issue. My Sea Urchin works for about 10 minutes, then loses all delay, and won't work anymore. I initially thought it was an LM7805 issue, so I changed it out, as well as changing out the PT2399, but no dice. Any ideas?
-Charlie
sgmezei
Hmmmmm any pictures? And have you double checked all of the values on your board?
I know I had a sunking that would work for 2 mins then go caput because of some wrong values.
ckim715
-Charlie
sgmezei
Well first, I would add a PT2399 chip.......... ;D
I am on the road this weekend so I can't offer any more advice on this layout. Is this the one from Josh?
ckim715
I don't know where I got htat number from. It's an LM7805.
-Charlie
Have you checked to make sure it's putting out 5v? Also, try powering it up and check it continuously for about 2-3 minutes with your DMM to see if the voltage is draining somehow.
Where did you get you pt2399's from.  I had a lock up problem with a batch off ebay.
Josh
Quote from: gtr2 on February 26, 2012, 12:58:30 PM
Josh
It would seem that's not the case here since it's not locking up when powered on. Or, did you have a similar experience with the bad batch?
Oops I didn't see the 10 min part.  Mine were locking up on power up.
Josh
Quote from: gtr2 on February 26, 2012, 11:57:19 PM
Josh
You can actually design something around that if you use an LM317 instead of the regular 7805. The datasheet has a little circuit for a slow warm up....I think that might take care of the lockup problem. I've tested it out, but not on a PT2399. It's really similar to the anti-lockup circuit from the Little Angel, except in that case it doesn't control the regulator but the VCO pin of the PT2399. Obviously, that way works really well, too!
ckim715
I checked the voltages with the DMM, and I'm getting 5.1 VDC into pin 1 of the 2399. Just to make sure, when I check the voltages, I can ground out the ground lead anywhere, i.e. on the case, right?
-Charlie
ckim715
#12
Also, my LM7805 is getting warm to the touch. Is that normal?
Here's the pin readings for the 2399.
1: 5.1
2. 2.54
3. 0
4. 0.17
5. 3.02
6. 2.55
7. 4.4
8. 0
9. 2.55
10. 2.55
11. 2.54
12. 2.55
13. 2.53
14. 2.53
15. 2.54
16. 2.55
TL072
1. 3.26
2. 3.26
3. 3.26
4. 0
5. 3.26
6. 3.26
7. 3.26
8. 6.52
-Charlie
ckim715
Josh
I got them from Tayda. I've used 3 separate PT2399s all with the same symptom..
-Charlie
The TL072 is problematic. Your supply voltage on pin8 is only 6v. It should be 9v.
