DigDug V2 (UPDATE: Works great!)
Started by neiloler, August 31, 2010, 11:57:27 PM
neiloler
Hey! Yup, you nailed it: prepainted box, water slide decal. I got the decal material off of ebay from some scrap booking materials seller. Nothing fancy.
The side switch was done because I tried the top mount switch, but didn't have room. I think I could have done it if I had drilled a little lower. I'm not by the pedal right now and won't be for a bit (school just started in electrical engineering land  :-\), but I might look into Small Bear's bigger box, or just make sure you plan out the layout VERY carefully, taking into account the rounded corners of the inside of the box (that's the reason why my switch didn't top mount, but I drilled a hole for it... :-\).
Good luck!
OLERAudio - Sole proprietor, engineer, and goofball
neiloler
