Wolfshirt Test BIG RADIO?
Started by pryde, February 18, 2012, 08:51:02 PM
pryde
Hello,
Just tested my wolfshirt circuit (rock it before you box it) and everything works EXCEPT it is picking up a local radio station very loudly. I had the circuit board grounded with the test rig and all. I tried a couple different power sources, including battery with the same result. I also clipped a bunch of different resistors in-line with the input and also a capacitor between input and ground with no change in the loud radio.
I built the circuit to spec using the 2N3565 trannies. Should I expect this to go away after it is boxed up or is there something I should check on the board? Note: My zombii also picks up "faint" radio but not near as loud as this. Any ideas bout what to do before boxing?
Thank you.
FYI: This build is a "Radio Rock It Before You Box It"
I was listening to a nascar race before I boxed mine up  ;D
Josh
pryde
OK then I will box it up and see what happens.
Thank you.
