how to build a transistor tester
Started by sgmezei, February 13, 2012, 08:01:47 PM
sgmezei
Okay, so I ordered a batch of 100 Russian transistors (GT108V)  and 20 GT402E and I want to build a rig on perf board to test them. I am following RG's article seen here:
http://www.geofex.com/article_folders/fuzzface/fffram.htm
An excellent article!!!
What I would like to do, is use my 1spot adapter which puts out about 9.4 volts but it is constant.
Do I have to adjust the resistors to make my DMM read the "correct" values at the end of the procedure?
Any advice or help with this project is much appreciated.
jrod
That should work just fine with your adapter. Not sure what you mean by "adjust the transistor" but considering the way ge's are sensitive to temperature that .4V over 9V should not make much of a difference if any at all. Just pop the transistors into their socket, let em settle, measure, do the math, and you should be good! Those Russian transistors are great. I have some GT109 that I like a lot and GT402's that are great too.
sgmezei
whoops!!! I meant resistors, I fixed it  ;)
sgmezei
How many good sets did you get out of your batch?
cjkbug
you could use a 9volt regulator after the 1spot to get a stable voltage. and make sure you let them stabilize for a few minutes before writing the measurements as handling the transistors will add heat.
sgmezei
Okay, I got a big batch of Russian Germaniums and started to test some of them out. It is late and I need to ask some dumb questions.
I tested a bunch of them and am not quite sure I am doing it right.
RG method from his fuzz face article
I measure across the 2k7 resistor and got my first reading.
I then connected the 2.2M resistor and measure the DC across the 2k7 resistor again.
Is this correct? Am I measuring the 2k7 resistor both times?
Well I got these readings on a few:
The first number is the leakage and the second is the gain (if I am doing this right)
0.55 , 1.45
0.4 , 1.12
0.14 , 0.83
2.07 , 3.37
0.22 , 0.91
So would the first transistor have a gain of 90 hFe?
I figure this out right because I have 140 to test.
Help me Team!
sgmezei
This is the meter setting I am using. I want to make sure.
plesur
#7
If you are using 2.2M and 2.49K resistors from what I understand, you multiply your readings by 100 then subtract one number from the other.
So (1.45 - 0.55) * 100 = 90
So you are correct.
RG thinks that any leakage over 500uA is bad. What's the leakage on this one?
0.55/2472 = 0.000222 = 222uA
So anything up to 1.23V on the leakage side is 'usable'.
So the second transistor is also somewhat leaky and the fourth one is faulty.
But you'll need to adjust for your resistor values, as this is approximate.
( Edited to clarify leaky transistors )
claytushaywood
Isnt the first tranny getting close to "too leaky" as well?
So I have a multimeter that tests transistors... this does not test for leakage though, correct?
Is this method that RG describes as accurate as a bought transistor testing device?
For those of you that have bought large quantities of transistors off ebay or something... how are they?
Any of you sell them?
sgmezei
Thanks Plesur, that is a huge help.  Good to know I am somewhat on the right track.
Claytushaywood, if you haven't read the RG keen article above, Do It, I found it really helpful. New/cheaper multimeters don't really test for leakage or account for it AFAIK.
This is my first batch of tranny's off of ebay so I will post the gains I get. Don't know how many good ones I will get so I won't offer to sell any hahaha.
claytushaywood
cool!  let me know! yeh i had just been reading it.  though i was dozing off and my comprehension was awful.
but yeh, let us know about how it turned out.
sgmezei
Okay so here is what I got for GT402E, I ordered 20 of them and I believe 19 are useable.
The third number is the Hfe
        1.   0.16, 1.01,  85
   2.   0.28, 1.27,  99
   3.   0.30, 1.82,  152
   4.   0.20, 1.23,  103
   5.   0.10, 0.89,  79
   6.   0.30, 1.52,  122
   7.   0.23, 1.04,   81
   8.   0.32, 1.81,  149
   9.   0.20, 1.15,  95
   10.   0.68, 1.71,  103
   11.   0.25, 1.15,  90
   12.   0.49, 1.86,  137
   13.   0.21, 0.98,  77
   14.   0.28, 1.61,  133
   15.   0.24, 1.05,  81
   16.   0.40, 1.60,  120
   17.   0.26, 1.43,  117
   18.   0.48, 1.53,  105
   19.   0.29, 1.27,  98
   20.   2.14, 3.78,  bad bad bad
claytushaywood
very nice... got some fuzzing out planned do ya?
plesur
These look like a nice set of trannies, low leakage, good gains. There's a few fuzz face and tone bender sets in there!
I just might get me some of those too.  ;)
Some of the Russian germaniums have an internal "shunt" resistor that makes measuring the gain accurately very difficult. The big-ass GT404 trannies don't see to have them, but the smaller flying-saucer trannies usually do.
On the other hand, the Russian trannies are generally far more modern in manufacture than the "coveted" US/UK germanium units. As a result, they tend to have lower leakage and lower failure rates. At least in my experience, that is.
