Cave Dweller - baby build
Started by madbean, February 02, 2012, 03:16:48 PM
saxoftenest
FYI, the blue sparkly enclosure is impatiently waiting for this board. I shall call it the "Tardis" or "Wibbly wobbly timey wimey", I have yet to decide. I guess that'll be something to think about to pass the time... ;D
Mmmm good.  Are those edible enclosures?  They look tasty! ;D
I love sparkles.
I have a pedal coming that's the PPP white sparkle custom colour. Super pricy, but it's an awesome enclosure.
Loztboy
Interesting! looks like a tight build, I like it!
The swells you create from 1:26 is created together with the guitars volum knob or volume pedal right?
G.G.
Any chance of a peek at the BOM, even if it's not final? I'm putting in a Futurlec order . . .   8)
mjcyates
Here's the schem. What's missing is a single cap after R6--it will most likely be 100n, but I will confirm once I check my breadboard again. It's to remove some of the DC noise on the mix pots.
50kA might also be a better choice for the Dwell knob, since the best action on it happens in the first half of the rotation, but linear also works fine.
It requires 1/8W resistors and multi-layer or monolithic film caps. Tanatalums for the electrolytic is also a good choice. C13 can go as low as 10uF (that's what I used).
Ettore_M
 :o ! That's awesome, Brian! :) What an awesome sounding pedal! And it's in a 1590A.. F@#%ing badass! Well done!  ;)
I loved these volume swells you did in the demo! Great sound! What that only Cave Dweller and the guitar's volume? Or did you use another pedal?
- Culturejam
saxoftenest
Quote from: jkokura on February 03, 2012, 04:19:13 AM
I love sparkles.
I can't pass up a good sparkle. The PPP white sparkle is awesome - I ordered some blems from them a while back, one of which ended up being a 1590BB in white sparkle with a tiny spot of black on the side. It's purty. :)
Thanks for the schem, Brian!
G.G.
Thanks Brian!  Looking forward to this, gonna try my first 1590A  :o
Quote from: madbean on February 03, 2012, 01:30:26 PM
Here's the schem.
bigmufffuzzwizz
I can't believe how good it sounds! It's just what I neeeeed...w/ tails though...
Om_Audio
sounds really great- def will build one of these- I find it very hard to find new pedals that time adjust like tape or BB- where it sounds JUST like slowing a tape or vinyl. Hmm- 2 of these in series in an enclosure...
djaaz
These baby boards look really promising.
And actually, i'm thinking putting many of them in a 1590BB enclosure.
I was thinking to build a few modulations for bass. Could be a smart way to to do an "all in one bass effects" pedal.
lego4040
 :o I will be getting my board when available ;D Brian I did my own pcb on the v1 and i dont know how similiar they are cause i havent compared the schematics yet. You said a 100n after R6, is that in series or parallel to ground. I also see your using pin 13&14 which Ill have to do a sister board for
Cannibal
hello! That's my first post here and i just want to ask you where i can add a wet effect loop. Is it possible to add it after the r6-c7 junction? And if i'm adding the effect loop there, would the first repetition be effected?
