EgoDriver - older version
Started by Mike B., January 29, 2012, 11:05:27 PM
Mike B.
Does anyone happen to have the old PDF instructions for the EgoDriver (pre Sept '11) - or is there a section of the forums for retired build docs? I'm catching up on some builds and just noticed that this one is different from the board that I have.
Thanks!
Haberdasher
I don't know if you've already looked, but there is an archive section and it contains a zipped egodriver file.  The version you need might be in there.
http://www.madbeanpedals.com/projects/archive.html
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Mike B.
Yep, it was there. Much thanks Keefe!
seven64
i bought a non-working egodriver, and it seems to be older then anything in there.  i have pics of the pcb if that helps.  i just wanna find the project file for this version, as it would help speed up the process of getting this thing repaired.
seven64
here is the pcb.  i think i need to do some major desoldering to start.......
