Off Board wiring issue I think - see pic
Started by andyo64, January 29, 2012, 01:35:37 AM
andyo64
Looking for some help on a build I just completed (SK)- not sure if its that its off board wiring is correct.  I used a DPDT switch instead of the 3PDT shown in the build doc.  All voltages are correct to the ICs so I figure its the off board wiring.   See attached,
Thanks,
Andy
I think your switch wiring is incorrect, and your output jack needs to be grounded to the rest of the circuit in the meantime.
andyo64
Yea - that's kinda what I was thinking of too.  The Sunking doc doesn't show how to wire a dpdt with the single sided board.  I did find this though not sure if it will work,
http://www.muzique.com/schem/dpdt.gif
Andy
andyo64
Jacob,
That's it - the grounding of the output jack!  Everything works now,  Thanks,
Andy
