Waffle wah.
Started by JakeFuzz, January 26, 2012, 02:32:13 AM
JakeFuzz
Well I think I will be doing more tweaking this weekend but here is a clip of it with a few different effects.
The Sunking uses a 10n bass cap and has a BAT41 and BAT46 (I blew up my LM313's  :'() and has the 1M gain resistor. The fuzz is my purple CV7112 Fuzz Face, the wah effect definitely gets a little less when playing with fuzz, time to tweak some more  :D
http://soundcloud.com/jakefuzz/waffle-wah
it sounds like you're getting a combo of volume and wah happening simultaneously early on... sorta weird.
jimmybjj
#2
......almost like you have some type of envelope type thing going on.
Pcbs no longer available
cjkbug
Quote from: jkokura on January 26, 2012, 03:21:21 AM
yeah seemed like there was a big volume drop at one end of the sweep
plesur
Weird volume fluctuations there.
Apparently you can make any wah into a volume pedal by lifting the ground connection of the 4uF capacitor, so that might be a good place to check.
JakeFuzz
I was tweaking with the values all last night and found something very interesting; my filter section doesn't work like it is supposed to. I took the frequency pot out of the mix (and that second cap) and it sounds absolutely epic now, similar seep range as my Wizard but much much warmer. No more crazy volume drop. I am just going to leave the pot and and use the external control for something else (peak maybe).
I did check the 4.7uf cap as well to make sure that wasn't giving me any problems. According to Keen's article this is responsible for changes in volume throughout the sweep.
What I found was this; the capacitor that is always connected to the feedback loop (3.9n) has a huge impact on the bass frequencies through the majority of the sweep of the Freq control. In other words, there is not a smooth blend between 3.9 and 100. The pot was adding very small amounts of bass to one end of the wah sweep until it shorted to the 100n when then there was a sudden large change in resonant frequency. I tested the other way around (100n always connected) and was getting the same thing except reverse (super bassy all the way up).
Ill post another sound clip tonight or this weekend but the change is huge. I am using a 15n feedback cap but may switch to a 22n.
jtn191
#6
Quote from: plesur on January 26, 2012, 03:42:09 PM
very interesting...so you could make it a wah/volume pedal by putting that connection on a switch
Quote from: JakeFuzz on January 26, 2012, 03:54:39 PM
cool, excited to hear a demo. fwiw, the whipple sounded pretty incredible even in the volume drop demo
Thanks for giving your feedback. 100n might be overkill, so it may be worth mentioning in the doc that smaller values might be more palatable if one is using the Freq control...I tend to go for extreme settings sometimes :)
One thing I did not mention in the doc was that there is a little amount of "play" in the full turn of the ICAR shaft and the pinion, meaning it's possible to go just a bit high or low when trying to marry the two things together. I did a small readjustment to get the range I liked on mine by lining the teeth up a little differently /
JakeFuzz
#8
Oh hellz yeah.
http://soundcloud.com/jakefuzz/wah-new
This is the sound I was hoping for. Took out the Freq knob and replaced with a 15n fixed cap, returned the input cap back to 100n. This thing sounds amazing  :o Much warmer than the Wizard wah, extreme range on the sweep now. You can actually drive the transistors to get a little grit with heavy pick attack (220R emitter resistor) and it sounds epic, little volume boost. Overall probably the best sounding wah I've ever played and I though my Wiz clone was the best. Stoked :D. Added a mini rotary switch to my SB order so now the Freq knob will be a cap selector switch, the blend just didn't work for me.
EDIT: oh yeah forgot to mention. I am using my '51 style telecaster into my twin reverb. The egeodriver uses stock clipping and a BB opamp. The fuzz is my prototype hybrid with a 2SA1015 and an IT308B.
Paul, I'm so glad you are pleased! The wah sounds great.
If it's okay with you, can I add your suggested mods to the doc? I would like to give a small warning that the Freq control might not suit everyone, and let them know what you found.
JakeFuzz
Yeah of course Brian. I was interested to see if anyone else had the same result or if I was using a strange pot or cap or something. I suppose we'll see soon.
Paul you do great demos... great tones and nice chops 8)
Until now... I didn't need another wah! ::) ;D
JakeFuzz
Quote from: nzCdog on January 27, 2012, 04:06:32 AM
Thanks Corey! I love trying out the new gear.
This wah is so awesome my gastrocnemius is starting to hurt. I am going to invent a new term called "Waffle Leg"  ::)
Quote from: JakeFuzz on January 27, 2012, 04:18:26 AM
LOL!  I googled that... Take it easy , don't do yourself an injury! :D
plesur
Wow, that wah sounds great now. Some of the slow sweeps with the EgoDriver on sound really psychedelic.
Can't wait for my board to arrive now!  :)
