The wild addiction of pedal building
Started by pickdropper, January 15, 2012, 08:21:33 PM
pietro_moog
in these diy years i build
-2 amps (a vibrochamp, and a 18w jcm800 od channel + ef86 based clean)
-a reverb unit based on a hybrid fender/ampeg/6bm8 design, very cool
-10 pedals, they'll be 14 in a few months, i don't have too much time right now
-a guitar (jazz master with humbucker at the bridge, very nice, painted by myself)
diy is fun
i don't think it's THAT addictive,now i'm at the point where i don't know what to build next.
i don't think i need anything more..
however my rule of thumb is: build just what you use, and recycle what you don't use anymore. don't waste resources.
bigmufffuzzwizz
Quote from: jimmybjj on January 20, 2012, 12:39:53 AM
Quote from: bigmufffuzzwizz on January 20, 2012, 12:30:38 AM
Your gonna fit in just fine! I always make sure I have 20 projects lined up and then I get side tracked and build other stuff. Finally bought my first amp kit, waiting for it to arrive. See the doors are opening!
Cool Magic, what kit did you go with?
After doing a bit of research (probably not quite near enough) I went with a Weber 5F1 kit, basic tweed. The part that made it most worth it to me was the inclusion of a cabinet all for about $450. I'm hoping my options open after I build this one and I can start DIYing like I do with pedals. I'm love to get all over the Ceriatone site, champ heads, jtm45/100 and superleads..
I'm about to pull the trigger on a trinity 18W...  uggghhhh GAS!
http://trinityamps.com/Product_Parts.htm
jimmybjj
Quote from: bigmufffuzzwizz on January 20, 2012, 12:53:30 AM
O
Nice, hard to beat that for the money.
Quote from: nzCdog on January 23, 2012, 02:11:09 AM
Do it! :) My favorite amp is a 18 watt (lite IIb) that I built. Everyone that plays it comments on how good it sounds :)
Pcbs no longer available
TNblueshawk
John
Thanks TN...that's the very same kit I want to build :)
Gonna prolly put one of these VVRs in to tame the Volume instead of a MV... just about enough cash, gotta sell a couple more things first :)
TNblueshawk
What is that thing doing nz? Is it acting like an attenuator of sorts?
John
'Variable Voltage Regulator' starves the volts going to the power tubes, decreasing the power output of the amp, down to 10W 5W or Wattever ;D... whereas a Master Volume attenuates the preamp signal going into the power tubes.
From what I've heard 18 watters tend to sound better using VVR instead of MV
slimtriggers
Quote from: nzCdog on January 23, 2012, 11:14:41 PM
There are several VVR layouts around if you want to save some $$ and DIY ;)
http://www.sewatt.com/files/sewatt/vvr_tagboard.jpg
http://music-electronics-forum.com/attachments/11226d1286636081-vvr-layout.jpg
Thanks slimtriggers... I hadn't found any good layouts, definitely better to do DIY 8)
