Anamorph question
Started by TNblueshawk, February 22, 2025, 05:43:23 PM
TNblueshawk
Ok, so I built this and everything works but something is off OR maybe this is such a unique delay that I'm not understanding what the ideal sound is.
Before I post pics, voltages etc... I thought I'd start with a question first. It's hard to describe but for example as you play chords there is a huge swell up and down almost like you would set your modulation on any given pedal to extremes. Sounds trippy as hell and rather cool but no matter how I set either the trimmers or knobs it has this sound. Think WWWWOOOOoooooowwwwwwWWWOOOOoooooowwwwWWWWWOOOOOoooooWwwww.........   assuming that makes sense  :o
Is this what the pedal was designed to sound like? I found one good demo out there that kind of has that sound but not on the extreme of mine by no means.
One anomaly that I have is that for the khz check the lowest I could get is 111 Hz. No idea why. Checked the value of the trimmer and that's good. Maybe causing the issue?
John
