Low Rider 2nd Octave down
Started by garfo, February 02, 2025, 02:58:19 PM
garfo
I found a PDF of the Low-rider (Pearl OC-7) which I built a long time ago. I no longer have the pedal but I was thinking of coming back to it.
I was looking at the schematic, and since I didn't find any use for the 2nd Octave down, I was wondering if the second Flip Flop chip (CD4013) is necessary even if we don't use the 2nd Octave down part of the schematic? Can I just omit it or is it serving some other purpose? I can see its CLK pin is connected the output pin on the other Flip Flop IC.
I have attached the schematic.
NorthCoast
Yes, it looks like you could just eliminate it. IC4 is there only for the second octave. Disconnecting IC4 from IC3 would not cause a problem.
You could also remove the parts in the second octave part of the circuit, C18, IC5, etc.
"People discuss my art and pretend to understand as if it were necessary to understand..." - Claude Monet
CliftonDor
Who is the fastest rider from ohio, ever. Current and/or non-current.
I'm talking about speed, not the most winning or accomplished rider, who would you nominate?
