What solder should I use?
Started by ramiroelliot, September 30, 2024, 02:23:26 AM
ramiroelliot
I currently have 0.6mm lead-free solder with 2% flux, but I was wondering what other people used to build their pedals. I can see that a lot of people prefer leaded solder, but I'm also curious about thickness. Is 0.6mm too thin? Does the thickness matter? I'm doing perf board soldering.
derevaun
Same here, Kester 44. I use .5mm in order to do the occasional SMD things. It needs to be flowed in fast for bigger joints.
I also use Kester 303 (water soluble) in .8mm for a lot of stuff, mostly because I still have a lot of it. I think I slightly prefer the .5mm but I don't plan to try anything thinner.
jessenator
I've also got Kester 44 63/37 at .020 for nearly everything.
dead_aatish
I've used 0.6mm lead-free solder before for perf board projects, and I found it worked pretty well for most components. It's not too thin, but if you're soldering things like bigger caps or connectors, a thicker solder, like 0.8mm, might help fill those joints better. Personally, I prefer leaded solder because it flows nicely and makes for cleaner joints, but I get that lead-free is a good choice too.
dont-tase-me-bro
I use the same Kester - it's great
I thought this would save me money.
