Kingmaker24
Started by Norad865, August 20, 2024, 11:52:43 AM
Norad865
Hello, Im Michael. First post, I hope you guys can help me.  Im not getting any form of rate/speed from the kingmaker.  The depth,manual, and feedback are doing what their suppose to.  I cant get any movement from the lfo.  I used the V3207D/V3102D and the 2 jumpers are vertical. I followed the build guide to adjust the trimmers. I also changed the A250K speed pot.  Here are my voltages. Im using a 1 spot with nothing but the kingmaker plugged in @9V.
IC1 TL062
1. 5.06
2. 5.06
3. 5.06
4. 0
5. 4.61
6. 5.06
7. 5.06
8. 9.16
IC2 TL062
1. 5.07
2. 5.07
3. 5.07
4. 0
5. 5.06
6. 5.06
7. 5.06
8. 9.16
IC3 V3207D
1. 0
2. 4.51
3. 4.54
4. 8.55
5. 9.15
6. 4.50
7. 6.03
8. 6.03
IC4 V3102D
1. 9.15
2. 4.50
3. 0
4. 4.51
5. 0
6. 9.02
7. 3.40
8. 8.55
IC5 TL022  I changed this chip 3x's, from 2 different sources.
1. 1.01
2. 1.12
3. 4.52
4. 0
5. 1.02
6. 4.52
7. 1.04
8. 0.50
Q1. 2N5088
C. 9.17
B. 3.94
E. 3.68
Q2 2N5088
C. 9.14
B. 6.38
E. 5.96
Q3 2N5088
C. 9.14
B. 5.04
E. 4.47
Q4 2N5088
C. 3.79
B. 5.44
E. 0
I appreciate you guys, and thank you.
If you look at page 4 of the BOM, you can see where IC5 gets its power. Check for continuity in that area. Also, remove the IC and check your voltage in pin 8.
Norad865
Thank you, I will try that and see how it turns out
