LectricFx Dandy Horse Musikding Parts Help
Started by Pish, May 16, 2024, 11:08:34 PM
Pish
Hey!
I got the Dandy Horse kit from Musikding and the BOM says that the feedback pot should be A10K but they sent me a C10K. Is this right or should I replace it with what the BOM asks?
Is the build guide out of date or have they subbed a part in to get the kit out to me. (Also other bits missing but not the end of the world, tho, this seems to be a consistent theme with them for me)
Cheers crew!
Sounds like a part was subbed, BUT the C10 will give you a little more control than the A10.
Pish
Am I right in saying that the inverse here is same as reverse?
So not much change between no feedback (at full resistance) and 2 but better smoother control for the rest of the range?
https://eepower.com/uploads/education/potentiometer_taper.png
jwin615
Your bunching of control will be at minimum feedback setting with the C taper. That will allow finer control I. The medium to maximum feedback range.
With an A taper, the opposite would be true.
Pish
Does it matter which way up the rotary switch is?
Asking as the pins are numbered.
Cheers
If there are no markings on the bottom of the board, nope. It will only go in 2 ways and both sides do the same thing.
Pish
Quote from: jimilee on May 22, 2024, 08:15:54 PMIf there are no markings on the bottom of the board, nope. It will only go in 2 ways and both sides do the same thing.
Thank you
