Vox wah vero
Started by jimilee, March 27, 2016, 01:47:49 PM
Thomas3D
Modified enclosure by drilling out one of the corner mounts. Lots of planning to get this in there and working. 1/8 watt resistors and low profile electros made it possible
Sent from my SM-G950U using Tapatalk
Thomas3D
Thomas3D
Thomas3D
Modified enclosure by drilling out one of the corner mounts. Lots of planning to get this in there and working. 1/8 watt resistors and low profile electros made it possibleTenebrion reverb in a 1590a  https://imgur.com/gallery/oAAZn
Thomas3D
Thomas3D
chongmagic
I've been wanting to build this for quite some time. I am still new at graphics but here is my rendition.
Sent from the unknown
chongmagic
chongmagic
chongmagic
chongmagic
chongmagic
chongmagic
I am building the multiplex and mod and eventually adding the run a dub reverb. I figured I would test the multiplex and mod first before I added the second effect. I used the 1776 3pdt board and connected up the power and I/O jacks. I get all the LEDs the light up on the 3pdt board , the modulation LED changes rate, and the speed switch LED lights up very dimly. Bypass works but I get nothing when the effect should be on. Could one of the pt2399 chips be bad? I don't have it boxed up really could it be a grounding issue?
chongmagic
chongmagic
