Current Lover 2023 Build - With a Dino Theme!
Started by Fingolfen, April 30, 2023, 11:15:50 PM
Fingolfen
I've built tons of pedals, but I think this may actually be one of the first Madbean boards I've finished... though I've already built three (one for me, and a couple for friends)... and it won't be the last...
I had a friend who wanted an old-school Electric Mistress clone, but the only one I'd built was the PCB Guitar Mania one - which actually worked pretty well, but given it was essentially a copy of the Madbean version, I figured I'd go with the real deal going forward. Unfortunately the old Current Lover was out of stock... but fortunately he just released a brand new version. This new board includes a volume knob, support for multiple BBD chips, and multi-voltage support (up to 18V) - so I decided to get cracking!
As you can see from the board above, there are a lot of ICs that go into cloning the Electric Mistress. By and large these are all new production from Mouser, but I am using a vintage MN3007 BBD chip I picked up locally (...and by picked up I mean I bought them out). The rest of the components are all new as well. The resistors are 1% metal film Yageo and KOA Speer, the film caps are a mix of WIMA, Kemet, and one Panasonic. All of the electrolytic capacitors are from Nichicon. I socketed all of the ICs as well.
Because the build supports multiple BBD chips and voltages, you have to make a few decisions when populating the board (unless you want to socket a few extra components). There are a couple of places for jumpers in the middle of the board that let you set what type of BBD you're using. As I planned to run these using the MN3007 at 18V, I went ahead and hard wired the jumpers rather than socketing them, though that is an option. However if you change voltage and/or BBD, you'll need to completely recalibrate the unit (see below for details). There is also space for a regulator that is only used if you're running at 18V, but as with the jumpers it can be socketed. I hardwired mine.
Once the pedal is together, it has to be calibrated so I got Steggi to help with the that! The Madbean instructions are really very good and they walk you through the whole process - starting with basic transistor biasing and then setting the limit for the BBD and the clock rate. This can all be done by ear which makes things much easier than pedals you have to pull out the oscilloscope for!
The whole pedal fits snugly, but very comfortably in a 1590BB2 enclosure. Because I wanted to route the input and output audio wires as far away from the circuit as possible (to limit any tendency for the effect to pick up noise), I decided to go with Lumberg jacks rather than my normal Switchcraft as they kept the audio path well away from the PCB. You can just see the black and purple input / output wires running along the left hand side (from the bottom) of the enclosure around to the back where they connect in to the jacks. I went ahead and braided the power and ground wires together and hooked them into the DC jack. This design had well-placed pads for the audio jack grounds, so I used them to keep those lines short. All of the connections to the jacks are insulated with heat shrink tubing.
I wanted to do some thing fun for the enclosure, and our mascot this time is the Minmi - which is an Ankylosaur. The artwork here was done and published by Tuomas Koivurinne, who kindly gave me permission to use it on the pedal.
This new version of the Electric Mistress was originally commissioned by a friend who wanted their personal logo added, and decided to go with a slightly different LED - so his version is above.
In terms of the sound, it really captures the old school Electric Mistress perfectly, with some added functionality. It is also extremely quiet! While I could hear some very faint "swoosh" during initial testing, once I got the pedal actually boxed-up in the enclosure, that disappeared. While my previous build was reasonably quiet, you could still hear some slight modulation of the baseline audio signal in some cases. I haven't pushed this one to the limits yet, but it does seem to be a much better layout overall!
There's a bit more at the blog: https://steggostudios.blogspot.com/2023/04/a-new-electric-mistress-clone-with.html
jessenator
This is seriously cool! Very well built and laid out! Well done.
[NOBODY CARED ABOUT THAT]
Man, that's killer. I didn't realize they were taking Brian's stuff, too.
Fingolfen
Quote from: jimilee on May 01, 2023, 02:32:45 AM
The dinosaurs are taking over! :D
That graphic is beautiful! Seriously impressive build, and I'll bet it sounds awesome.
