New to me guitar day
Started by Thewintersoldier, March 19, 2023, 02:39:23 PM
I'm always talking about how I struggle to find a humbucker guitar I like. Most are too dark sounding, too muddy to me. I like P90s but only when they do that certain P90 grind. I'm always searching for that perfect HB guitar that is like a tele on steroids. So I got a tele on steroids.
I found a deal on a 2021 vintera telecaster deluxe at guitar center and took the plunge. Turns out the perfect scale length for me is 25.5". I play teles all the time so this felt like home. These are the revoiced alnico wide range HBs that Tim Shaw worked on. They are very clear, bright and articulate. And after years of playing Les Pauls the control layout felt like second nature.
I replaced the pick up selector switch and jack with switchcraft parts as the stock stuff felt cheap. While I was in there I added some treble bleeds and an electrosocket jack cup like I do in all teles. I want to clean up the wiring because fender always has too much wire but that's for another day. I polished up the frets and did a full setup and man does this thing fuck. My SG is jealous already. RIP Gibson. Also a family photo of the current fender stable.
Sent from my Pixel 7 using Tapatalk
jessenator
That's a beaut, Chris!
Your description kinda makes me want to get 'buckers again...had a love\hate relationship with them in my gigging days. You also remind me that the jack in my Offset Tele is almost to the point of pooping out the lead by g-forces alone.
Good stuff, man.
"All you need is fuzz"   ~not Lennon
Ohhhhhhh very nice. I love that fat headstock, too. I a black one with the newer headstock but still with Tim Shaws.  I haven't played it in a while, I need to get it back out.
That's awesome, congrats!  I love the sound of those pickups and I'm not sure it's not my imagination but I've always thought fatheads sounded a bit more full range.  My 71 strat has a CBS fathead and although the neck is a complete turd the sound gets destroyed if I replace it with a more modern (or more vintage I suppose) neck.
bantaxes
I see it's been a while since you've posted, but I'm curious—did you ever figure out a good fix for that bypass switch behavior? I've run into something similar before and found that a small ceramic cap across the switch lugs helped tame popping. Wondering if you tried anything like that, or found another workaround that worked better for you?
