Misfit questions
Started by Lgmlgm76, December 08, 2022, 01:01:46 AM
Lgmlgm76
I noticed on the Projects(DIY) page the Misfit is listed as a 1590B build, but on the PDF instructions there is only a 125B drill template. Could I use either enclosure?
Also, it says the CA3260E has a 16v supply limit. Will this sound fine with a 9v supply or should I opt for higher?
Thanks!
mauman
It's a 125B, the 1590B is a typo.
Ibanez designed the circuit for 9V, I've tried it at 12V and it doesn't sound any better, so I'd stick with 9V.
Lgmlgm76
Quote from: mauman on December 08, 2022, 01:10:14 AM
Thank you kindly!
