Dr Boogie....
Started by Willybomb, September 20, 2022, 02:44:25 PM
Willybomb
Had this populated for ages, not a massive fan, decided to finally box it, might need more biasing even though everything is at 4.5v
Anyway, Tayda UV print using my "new" art style taken from my massive lack of inspiration.  Very tight fit into the 125b.
Is it as difficult to dial in as a real boogie? @harryklippton said you need a phd to dial one in lol. At least it looks cool.
Naaahh it's easy to dial in, as long as you can hear...as a deaf guy, I have trouble. That looks killer.
Willybomb
It has a fairly narrow adjustment range with the trimpots I used, like, you breathe on it and the voltage will move by a couple of volts.  I really need someone else in the house who can play while I adjust.
That sounds like an excuse to buy a looper pedal....
BryGuy
I dig the look, especially those knobs. Very slick.
Maybe one of those trimmers with multiple turns would be appropriate in this instance.
Quote from: Willybomb on September 20, 2022, 10:25:14 PM
Yeah it does. The triple wreck is even heavier. More chug for your buck! I do like to set the pots at about 4.5v
Willybomb
Yeah, I built a triplewreck a few years ago, that had a lot more gain than this.
