Shortbus - TIM
Started by madbean, April 10, 2022, 12:54:08 AM
I've had the real deal Tim, and then my 1590BB clone of it for many many years. I guess I started this 125B version in 2017. I think I etched the faceplate two years later. Finished it off today while I was working on the many new builds. Slight misalignment with the clipping switch so I had to overdrill it. Sounds great! My Danelectro likes it very much.
Bit of a pop with the bypass. I used some water clear white LEDs and massive 470k current limiting resistors to make them pretty dim when lit. This is one that would benefit from relay bypass, I think.
That turned out well, nicely executed.
harryklippton
This is where I learn that there is a different pedal called Tim and it's not just like a shorthand for the Timmy
