Madman
Started by Aentons, January 05, 2022, 02:11:15 AM
Aentons
This is a VFE Distortion 3 & Rocket EQ in a 1590BB
The idea is sort of a Randy Rhoads in a box type pedal since he was known for using the MXR Distortion+ into the old blue MXR 10 band graphic EQ. Since the D+ lacks a tone control it's a perfect combo.
Edit: as noted below, there is also a nod to Marshall with the knobs and the red and green LED asymmetric clipping.
The JST PH 2.0mm type connectors make it modular if I ever want to pull the boards out and put them in my eurorack pedalboard. These are smaller than the XH 2.54mm type which wouldn't have fit in this smaller enclosure.
https://www.mouser.com/ProductDetail/571-440054-2
https://www.mouser.com/ProductDetail/571-440055-2
https://www.mouser.com/ProductDetail/571-440129-2
https://www.mouser.com/ProductDetail/571-6-440129-2
https://www.mouser.com/ProductDetail/571-1735801-1-CT
I added the dress nuts to the A-1091 Tayda footswitch. The ones from SB didn't fit, and Mouser was the only place I could find a M12x0.75
https://www.mouser.com/ProductDetail/Apem/U411?qs=E8WiYJHGh1I6hHfWu6ClKQ%3D%3D
https://www.taydaelectronics.com/electromechanical/switches-key-pad/stomp-switch/spst-momentary-soft-touch-push-button-stomp-foots-pedal-switch.html
I also added a center detent to the 9mm "Soft" pot. Here is a walk thru of how to do it.
https://www.madbeanpedals.com/forum/index.php?topic=33286.0
Damn that looks clean. The Marshall knobs are a cool tip of the hat to RR as well.
Surely rocking! Looks great and lots of knobbies to tweak. Randy would have approved!
Aentons
#3
Quote from: gordo on January 05, 2022, 02:34:19 AM
Thanks! Yep, good catch! I forgot to mention the Marshall homages being the knobs and the red and green LED asymmetric clipping combo.
I like this! I also enjoy that RR sound even if I'm not a huge metal guy overall. I've got the fat and filter controls on my D3 set the same as you right now. I find my favorite sounds are with the hard control all the way left or right, then the soft at about 10:00 or 2:00 to add in a bit more texture.
That's awesome, but that font! I love it.
Quote from: Aentons on January 05, 2022, 02:11:15 AM
This alone is worth a BOTY vote.  The rest is great too, of course.
Beautiful build and a great idea!  8)
