Total Recall - Odd voltages on 4558 ICs
Started by zachlovescoffee, December 30, 2021, 02:47:01 AM
thomasha
Yes, that sounds the case. You can play with the cap and bypass other parts of the circuit to pin 3.
Stick one pin in the socket and solder a wire to the other and voila, you can now connect it anywhere where there is signal, even the input jack. The Cap will protect anything that comes after pin 3.
