What's Going on with Catalinbread's CB30?
Started by Bio77, December 19, 2021, 03:41:26 AM
I'm working on Aion's layout of the CB30 this weekend. The circuit has some weird features that I haven't ever encountered. Does anyone know what's going on with the (C11,C9), (C19, C18), (C24, C23) pairs? They look like a BP electro workaround but having the audio coming out of the middle of the two is something I've never seen.
That is interesting. I'd like to know myself. The only thing I can find that's close is biasing.
Quote from: jimilee on December 19, 2021, 04:41:25 AM
Agreed.  I think there is some deep cut pedal knowledge in this weirdness.
aion
This is mostly just because of the way I drew it. Look at the top one as the gate-source cap for the upper JFET (present in all mu-amp topologies) and the bottom one as the drain-gate feedback cap of the lower JFET that cuts highs. The lower one in each stage also has a series resistor to reduce its effect. Almost all of the CB mu-amp pedals have the same setup for their tube emulation stages, but usually they're lower-value film caps so it's more obvious what they're each doing.
Zerro
I guess it is about BIASing. Making current source for transistors working as amp stages. It gives better qualities for stable current no matter how gate - drain of that j-fet is set. Results in much lower noise and distortion at D-S pass. Something similar I encountered in electret mics current sources. You can sit here only simple resistor for power for mic. But you can put here such a current drived source, so that j-fet inside of mic can work under stable regime, which is primarly impossible for very specific setting of capacitor charge in that mic. See pict I attached.
"Nudíte se? Kupte si našeho cvičeného ježka! Pobaví vás svými veselýmí kousky!"
Quote from: aion on December 20, 2021, 06:39:17 PM
Ahh OK, so, the weirdness is just that it's electros. It's the orientation of the bottom caps that looks weird to me.  Thank Kevin!
Follow up question:  If I use an electro cap for  C26, should the + side connect to the volume pot?
Quote from: Bio77 on December 20, 2021, 11:37:51 PM
Right right. I need to look at more muamp topologies to become more familiar.
If I understand it right, negative should go towards the volume, if not, the signal wouldn't be able to pass through. That's a big if, I've been looking at schematics for a couple of months. Think about the feedback loop in the rat as an example. Again, that's IF I understand what I'm looking at correctly.
Quote from: jimilee on December 21, 2021, 02:19:02 AM
From what I have read, an electro needs a bias voltage to work properly, that voltage needs to be oriented correctly.   I don't think the signal cares which way it's going through the cap, as long as that bias voltage is there.  But grain of salt here, I am pretty far out past my knowledge base now.  My thinking is that C25 has a positive voltage on top, which draws a negative voltage on its bottom, so C26 should be oriented with the negative towards C25 and the pos towards the pot and ground.
Kevin had a 2n2 film in that spot, but I don't have any on hand.   I'll probably just try both ways and see if there is a problem.  Maybe neither is going to work  :P
Zerro
Maybe simulator will show values here. I use Caneda, and I can see. But not now, too busy.
mauman
Looking at C26, you have +VA on the other side of Q8, and ground on the other size of the Volume pot.  I think the north end of C26 will generally be more positive than the south end, so I'd put the positive terminal toward the north and negative toward the Volume pot.
