My foray into eagle and the results.
Started by jimilee, November 22, 2021, 03:37:56 AM
Quote from: NorthCoast on November 23, 2021, 01:28:10 AM
Very nice!
And bonus points for the resistor teepee!  :D ;D
:D Thanks you. Being my first attempt, I wanted to remove all variables that could make it not work, otherwise I would've used what ever I had kicking around. They all pretty much fired right up, I had to use a couple of jumpers on the PG14 for traces that didn't get connected.
Those layouts are pretty slick!
Only thing I'd suggest is making the traces thicker.
Quote from: alanp on November 23, 2021, 07:01:08 AM
Thank you. How do you do that in Eagle? I can google it, but if you know right off, and how much thicker.
I usually use about 0.4064mm for signal traces, next step up if I can get away with it. Don't know what that is in Victorian England units, sorry :) :P :)
Forgot to mention, I also love how you've integrated the indicator LED for the stompswitch in the same place on each board!
Quote from: alanp on November 24, 2021, 04:34:12 AM
Gotcha, and thank you. The LED is easier for me to work with when it's that low. It's also easier not using an LED bezel.
