Grean Bean & Crunchbox 2-in-1 (JGs "Sweede Tea")
Started by Geosh, December 16, 2011, 12:01:31 AM
Geosh
Based on the JHS Sweet Tea. I took the layout Brian had made for the Crunchbox a while back and used the Green Bean board for the TS side of the pedal. No labels yet and I drilled one of the footswitches slightly off, but overall it is a pretty sweet build. Too many knobs and switches but it adds for TONS of tweakability.
Oh and Brian (Bean), the new fabbed boards are NICE!! The only thing I screwed up was wiring the 9V+ to the negative pad on the board. Oops  ::)
I have a Fatpants, EgoDriver, and a Hotcake clone in progress. I will post those when they are done too.
jimmybjj
Very cool. Did you wire it, series with TS first?
Pcbs no longer available
snz728
nice build most wouldn't notice the switch unless you point it out
guts?
Geosh
The 3 mini switches are the fat, bright, and comp switches for the Green Bean. It is wired TS first in series now but I am thinking of adding a way to switch that. I have to fix something on the crunchbox side though so maybe I will take gut shots then. It was my first perf board build and I used a PCB layout so it was tight. It was working perfectly but maybe something got jarred loose or something and is shorting out.
Live and learn.
bigmufffuzzwizz
I really like the finish and the white knobs match it perfect!
