Pedal design help
Started by redkurn, August 30, 2021, 06:49:02 PM
redkurn
I'm interested in creating my own combo pedal, boost, overdrive, fuzz, a few switching between circuits and maybe a few stomp switches to turn them on or off.
How can I get started designing it?
I have a program for designing and testing diagrams, but not sure what to use in the design.
Zerro
That's very wide question - there are many schematics of FXs for any type of it all. Maybe at Youtube find some videos how to order stompboxes at first. And what do they do.
"Nudíte se? Kupte si našeho cvičeného ježka! Pobaví vás svými veselýmí kousky!"
Quote from: redkurn on August 30, 2021, 06:49:02 PM
Pick out your circuits and layout your idea on paper. For example, I built a multi with 4 circuits and order swithers in between each one. It was cool, but it got real complicated real fast.
redkurn
Quote from: jimilee on August 30, 2021, 08:09:40 PM
That's my general idea, a little complicated, but I'd like to design something new that will take up some free time to design, build and enjoy.
redkurn
Quote from: Zerro on August 30, 2021, 07:09:59 PM
I know it's a bit wide, but I'm just starting off with the idea. Want to make sure I have the best tool for simulating a circuit before I begin and then work from there, probably just combining fx into one box with a shared signal path, maybe something a bit more integrated. not sure yet.
I have LTspice, now that I am home and can read the program name, tinkered with it before and didn't really get expected results.
Zerro
Search at Youtube at first. Looking the sound you like. Many infos can be here from skilled users.
diablochris6
I agree with the advice above. Figure out what you want on paper. Draw a simple block diagram of the effects you want to use and figure out what effects you want to switch around. After that, look up order switching schematics and whatnot. When I plan things like this out, I use markers or colored pencils on signal lines to help me not get lost.
Zerro
#7
And at first positions are always EQ (what freqs send to chain and what not), gates (get rid noises), together with pre-EQ makes freq-gating, then mean effect (distortions...), then second EQ, and choruses, reverbs etc. And output volume booster.
Try to borrow gui multieffect pedal and try to order some segments, or to study their factory settings.
