How Do I Enlarge Just The Pads In Eagle
Started by skypn, August 10, 2021, 11:02:31 AM
skypn
I've just been chasing my tail with this, and I'm going nuts.  I've conquered (so far), the act of milling PCB's on my little CNC machine. I find the resulting pads are just a little too small for my limited skills to get an iron on after I  apply the solder mask, and would like to enlarge the pads on a component by component basis. All I need to change from the parts I'm using are the pads.
I tried to use the minimum size thing in the DRC which enlarges all the pads, but then the transistors, and IC's pads touch. I can enlarge those pads by hand, by just leading a thicker trace, then using a Sharpie to enlarge the mask printed on transparency paper to block the UV curing. Of course I don't want to have to do this for all components, but a hand full of pads are no biggie. Just a nudge in the right direction will help.
TIA
Knowledge for Knowledge's Sake
Not familiar with Eagle but, with another PCB software i use, i drop a single pad somewhere on the art, highlight it and every other pad/component i want to have with the same size pad, i then change the size of that single pad i dropped in and every other pad that is also highlighted changes to the new size. If you have a component with different shaped pads square/round they will all become the one shape.
No idea whether something similar would work with Eagle.
I'm an Eagle newbie, so, grain of salt implied.  It seems that you want bigger pads for resistors and caps but everything else is fine.  I think you might want to make a few custom parts for your library.  There was a JMK video tutorial for making parts, but it seems to be down.  You might have to search youtube.
yes, you need to modify the parts in the library.
Open the respective library, look for the part and right-click --> edit the pad you want to resize. You'll find inner and outer diameter to adjust.
Just make sure it is the same resistor, cap or whatever part that you also used in the pcb layout.
Once you did that, go back into your project and go to update library and that should apply the changes. maybe do a backup of the library and project before that.
skypn
m-K
Thank you! It took a little of trial and error to to get to where I needed, but I did find it.
P.S. I also learned a lot from your PCB etching tutorial.
you're very welcome. good to hear someone is still looking at my tutorial :)
Rockhorst
Eagle is so counter intuitive with parts editing. I have to figure it out from scratch everytime. Luckily that not often. Once you have the part, it's for keeps.
