wavelord - trimmer adjustment
Started by nicotina74, August 09, 2021, 10:54:57 AM
nicotina74
Hi guys, I assembled the wavelord and it's great !! A great pedal !!! In the pdf file there is written "T1: This trimmer sets the gain recovery after the LDR in the opto device. This is set by turning the Depth
knob to zero, Vol to about 2 / 3rd then adjusting T1 for unity gain with bypass. This setting should produce
minimal distortion at the output and allow for a bit of boost when you turn VOL all the way up .. "
I need information to adjust the trimmer ... is there a value that I can measure with the tester to understand when it is adjusted correctly? I hope I have explained myself, sorry for my bad english ...
Many thanks, Nicola.
Zerro
I would guess, that you must set it by ear while playing, with switching between bypass and effect.
"Nudíte se? Kupte si našeho cvičeného ježka! Pobaví vás svými veselýmí kousky!"
nicotina74
