Long time voyeur, first time builder.
Started by Pooch, August 05, 2021, 02:24:35 PM
Pooch
Hi all,
I'm very pleased to have joined the community and I'm looking forward to learning a lot and hopefully helping others where I can down the line too. I've followed a few folks' journeys from the sidelines as they've worked on projects and have decided to take the plunge and start on one of the DIY projects myself.
I should say that I'm not a complete novice when it comes to understanding schematics; I spent most of a decade working as an electronic security engineer and I'm currently part way through an electrical/electronic engineering degree which has - as you may expect - involved some tinkering and PCB construction using Eagle and KiCad (the latter of which I'm hoping to use to design the PCB and have manufacturered at a boardhouse).
I'm having a go at the "BFC"/Keeley compressor clone and just wanted to clarify a few things before I start soldering and collecting the relevant parts which may be (I'm hoping) very simple.
The thing that is throwing me is the "L" label/flag in the power circuit section at the top of the schematic drawing. Is this a general notation and if so what might have I seen it as before? I understand the global labels for VB and VC and how they connect to other parts of the main circuit to provide a reference or supply voltage (e.g. 9V to the LM3080 IC etc.), but couldn't find another "L" within the schematic to do the same.
I was also hoping to clarify the round "pin" marks on the schematic and what they mean or if they're just referring to the footswitch connections or something?
I may just be being dim or perhaps it's just lack of confidence for the first build but I'd really appreciate any help.
Looking forward to hearing from you good folks.
- Pooch
The little pin marks represent pads on the PCB. The L pin in this schematic is used to connect the LED to ground via the foot switch to turn the LED on.
Edit:  I just noticed, there is no LED in the schematic  ;D  If you look at another schematics, there is usually an LED after the 4k7 resistor connected to the L pad.
Pooch
Quote from: Bio77 on August 05, 2021, 02:52:38 PM
Thanks for replying.
I see, so the "pin" marks are basically just an indication that you'll need a pad here to solder the input/output jack for example? The LED was my first thought but presumed there would be an LED symbol if so. Then again, I guess it's quite cosmetic in comparison to the other components. I may post a picture of the finished PCB design on here once I've plucked up the courage to get going!
Cheers again for your help.
I think most schematics we work off don't include the switching and indicator led. The off board stuff almost never changes. Some of the companies who sell boards include a pad to connect the on/off LED hence it being included in the power section of the schematic you posted. Ultimately doing it that way saves a bit of trouble when things get wired up and boxed.
Brian is the king of the builder friendly layout.
Pooch
Quote from: matmosphere on August 05, 2021, 08:03:37 PM
Thanks matmosphere, I'll keep that in mind.
He is indeed the king.
