Zygote
Started by pewtershmit, August 03, 2010, 08:50:55 PM
pewtershmit
Hi guys,
Can I make a BC108 Fuzz Face from the Zygote? I'm pretty positive their fairly the same. Just thought I'd ask.
Also, Who sells BC108's for FF circuits?
Yep. Just reverse the orientation of the electrolytic caps and be sure use a negative ground wiring.
pewtershmit
pewtershmit
back again! got my boards in so I'm finally at this. Does the D1 need to be reversed as well as the caps? which wiring diagram can I use to wire this as a negative ground effect?
Yep, you need to reverse the protection diode. You can follow any of the negative ground projects for wiring...like the Serendipity or Neutrino.
brainbender
This is what i was looking for! Thanks! ;)
