SPST Switch for Mains Input Interrupt
Started by benny_profane, May 19, 2021, 04:36:16 PM
benny_profane
I'm putting together a project to have a mains input junction box for a board. I want to have one input with an interrupt switch feeding two IEC outputs (one to a power supply unit and another for a wall wart adapter). This switch seems like it should work and has the appropriate voltage and current ratings. Since the datasheet doesn't have the light circuit, I'm unsure if mains AC voltage will work with the illumination? The use case diagram shows an example with 12VDC. Will this switch work for my application?
