We need these kind of projects
Started by redkurn, April 24, 2021, 04:13:14 AM
redkurn
Noise Gate
https://www.amazon.com/gp/product/B015ZDDF0S
or
[youtube width=600 height=300]https://www.youtube.com/watch?v=wE94-lrF4Z8[/youtube]
Anyone else have a suggestion as well?
Aentons
redkurn
I know there are other sites out there, but wanted to continue support of Brian and these awesome forums.
I'll check it out though.
mbp does need a good noise gate project.
Zerro
#4
Maybe you should consider the beasties I attached. By a way, for hum and noise from single pickups could be good at first order a bandpass filter to avoid to send at Gate signals that are not usefull for guitar boxes - all except of cca 300Hz-7Hkz. So they won't make Gate to need to rise threshold and so to make signal too cutted. It's called "frequency gating". That DOD has simple HP filter (6dB/oct) at the input, at cca 330Hz. Cap 680pF reduces HF noise from single pickups, sometimes getting radio stations at input.
redkurn
Quote from: madbean on April 25, 2021, 12:55:49 PM
Woot!
Honestly I want one that will help with my pickups going microphonic at high gain, Seymour Duncan says it's normal for the SH-6(Duncan Distortion) to behave like that at high gain, but it seems to me that the first 3 days after installing them they were less noisy or prone to picking up every little bump.
They do scream though which is awesome.
Willybomb
Quotembp does need a good noise gate project.
Can I suggest this one?  I've snagged the image from Storyboardist, mind... so credit there.  BTW, it definitely needs a buffer in front of it for it to work properly.
