Whoa....green!
Started by madbean, August 02, 2010, 08:58:19 PM
I just got a huge shipment of copper clad in from my supplier. Finally, enough to last for a few months. The best part is the backing is a funky spotted lime green. I've never seen anything like it. Get ready for cool green boards!
pigyboy
Got my 2 boards yesterday, not series 420  :'(  .  These are my first boards from "madbean".  Awesome quality, they look much better than my home etching...  Now if I just had some time to solder.
Haberdasher
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
The 420 boards have the elemental form of the 420 green pigment and are far superior due to the following...
The 420 is a subatomic particle carrying quicker negative electric charge. It has no known components or substructure, and therefore is believed to be an elementary particle.[2] An 420 has a mass that is approximately 1/1836 that of the 400.  The intrinsic angular momentum (spin) of the 420 is a half integer value in units of ħ, which means that it is a fermion. The antiparticle of the 420 is called the positron, which is identical to the 420 except that it carries electrical and other charges of the opposite sign. When an 420 collides with a positron, they may either scatter off each other or be totally annihilated, producing a pair (or more) of gamma ray photons. 420s, which belong to the first generation of the lepton particle family,[10] participate in gravitational, electromagnetic and weak interactions.[11] 420s, like all matter, have quantum mechanical properties of both a particle and a wave, so they can collide with other particles and be diffracted like light. However, this duality is best demonstrated in experiments with 420s, due to their tiny mass. Since an 420 is a fermion, no two 420s can occupy the same quantum state, in accordance with the Pauli exclusion principle.[10]
Yes, well, according to Quantum Electrodynamics, the anti-particles will actual travel through reverse time, meaning circuits built on 420 boards will actually work BEFORE you assemble them!
:D
Haberdasher
aziltz
Quote from: gtr2 on August 17, 2010, 04:04:44 PM
Quote from: madbean on August 17, 2010, 04:47:59 PM
:D
Quantum Physics also states that more precisely I listen to my own playing, the fuzzier it gets, to about a factor of pi/2.
its good to see that i'm not the only one who could stay awake during quantum physics, at least enough to take the vocabulary and twist it.   ;D
pigyboy
Hey Man, I just smoked my board! 8)
Haberdasher
CRBMoA
I am bummed. I will not be able to do my long contemplated Pig Butt/Thunderpuss dual pedal. Surely if two 420's cannot occupy the same state, putting to 420 boards in one enclosure would either tear a hole in the space/time continuum or, more likely, it could set off a peristaltic chain reaction.
Bored
Quote from: madbean on August 02, 2010, 08:58:19 PM
Any chance you can share with us your supplier?
I imagine the 420 series board is strictly confidential!  8)
