Whetstone kits
Started by Drew Hallenbeck, February 10, 2021, 03:46:33 PM
I ordered them from BLMS as well
PapaKev
I found this wiring diagram. Hopefully it will help a few that have had difficulty tracing wires from other examples. Most everything is pretty cut and dry on the pcb. I was having more of an issue with 3dpt wire location on a few connections. This helped.
harryklippton
Quote from: HootyHoo on March 07, 2021, 02:48:24 PM
just know that you don't need to add that resistor for the LED, if you run the LED from the PCB, there is already a resistor on the PCB
PapaKev
Quote from: peAk on March 08, 2021, 07:06:52 PM
Good point! I forgot to mention that.
PapaKev
What dc jack are you using for this? I just noticed hole big this hole is.
Thanks!
Quote from: PapaKev on March 09, 2021, 03:05:14 AM
Thanks!
I just used a common one like this:
https://lovemyswitches.com/cliff-switched-2-1mm-dc-power-jack-outtie/
...but I did have to drill it a tad bit bigger, not sure if it was due to the finish or what.
PapaKev
#52
Quote from: peAk on March 09, 2021, 03:28:42 AM
Thanks!
Perfect. Thanks!
cajone5
Bit the bullet on this one.  Couldn't resist.  $80 for a whetstone kit with OG enclosure?  Yes please.
thesmokingman
mine showed up today with no BOM so I'm grateful to this thread for sharing
Quote from: thesmokingman on March 10, 2021, 07:20:07 PM
None of them had one I think.  I'm super happy Gordo posted it.
Still haven't even started on mine.  ;D
harryklippton
Quote from: culturejam on March 10, 2021, 08:53:00 PM
Same. Even though I was really impatient waiting for it to arrive
drezdn
Did anyone else pick up any of the other "kits?"
DLW
Quote from: drezdn on March 10, 2021, 11:36:45 PM
Yep - Whetstone, Fix'd Fuzz Deluxe, Cadvernous Reverb, and Crystal Dagger
