Bass Machine - Junk Trunk Gas Tank Combo
Started by Bio77, February 08, 2021, 12:56:27 AM
I've been wanting to use a powder coated 1590XX ever since Tayda started offering them.  Here is a combo of MB's Junk Trunk and Gas Tank.  I wanted these together to skip the 1/8 inch connection between the fuzz and the filter.
The fuzz sounds cool.  The filter is a bit finicky, but there are some sweet spots.  Together they give you some synthy goodness.
Madbean Bass Machine. Someone's a poet and don't know it.
Very nicely done.
harryklippton
That's badass sir. I was trying to decide which two to put together myself.
We've just seen a super clean mad bean bass machine.
That looks like they were designed to be boxed up like that!
TGP39
Wow.  Beautiful job inside.  Well done.
Super Clean John looks fantastic. I love the green and black, looks great.
Quote from: Bio77 on February 08, 2021, 12:56:27 AM
Does th envelope follow were still work if the gas tank isn't on, or is it just a cocked way sound?
Quote from: jimilee on March 20, 2021, 09:26:12 PM
The envelop works without the JT.  However, it's not my favorite envelope.  I wanted to build them together because of the clean feed from the JT to the filter.  I thought that was cool.
Quote from: Bio77 on March 21, 2021, 12:37:12 AM
I"m putting mine into a single also, I was just curious about the logistics because of the switching jack. Thanks the info.
CaptainPeyote
Hey, would you mind posting how to do the hard-wired envelope like you did?  It looks like only two wires are needed - and one is ground.  I'm assuming you just connected S to S for the ground and T to T for the signal line?  And assuming that's true, did you just use a meter to figure out which pad on the Gas Tank is ground and which is for envelope signal?  Thanks in advance :)
