A/DA Through Zero Flanger... Now in Stereo!
Started by danfrank, January 18, 2021, 12:48:28 AM
danfrank
Ok, so I had to build a second one of these contraptions... My 1st (prototype) one is on the left, the 2nd on the right. The 2nd one is so much cleaner looking because I already knew what I wanted in the build.
I used a 3.5mm jack in each box that I can use as an umbilical cord to carry over the LFO signal from the 1st one to the 2nd one so I can configure it as a
LFO "master/slave". Each box can be used independently from the other one also. I can also use both boxes in series for 4 delay lines.
I'll try to get some audio up soon
That's a lot of knobs you got there.
That's nutty rocket scientist stuff there. Great work.
danfrank
Oh yeah,
I forgot but the CV voltage (expression pedal) on these is 0-5 volts so I'll be able to use the Tappy or Wavelord as a LFO with weird waveforms.
I have to put my Wavelord in a box and I'll report back...
I need to buy a pink knob too...
