FatPants + GreenBean 2 in 1
Started by Jyka, January 04, 2021, 03:01:28 PM
Jyka
Hello,
My projects for this year is to make a 2 in 1 pedals : FatPant + GreenBean.
Do you you think fatpant is beter after or before the greenbean ?
mauman
Tough call!  I'd be tempted to add a "first side" toggle switch that would let you change the order.  Just one 3PDT and some wiring.  Mike
Flipper switch is the way to go.
Jyka
thanks for the reply
i was thinking to much to this diagram :)
Jyka
Jyka
And how many hours i need ?
I have to lock 2 or 3 hours for a first build ts8 ?
mauman
Quote from: Jyka on January 05, 2021, 08:30:23 AM
It's this one right ?
https://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
Basicly, you wiring diagram can change the position ?
You can use this one for a double pedal, and activate one side, the other side, or both sides.  However, the two circuits will have a fixed sequence.  It's missing the toggle switch that would change the sequence of the two circuits (left >> right, or right >> left.)
The diagram I posted does not show all the power and ground leads, and the foot switches are wired a little differently than the tutorial you linked.  Not right or wrong, just a different way to get to the same result.
The time required is difficult to say, we all work at different speeds.  I find it faster to work carefully, test each part before installing it, and avoid mistakes.    Mike
