Matching JFets for first time
Started by Aentons, December 31, 2020, 05:39:32 PM
Aentons
I have bread boarded a few of the jfet matcher circuits including geofex and the similar one in the nom-nom doc and I'm not having much luck. They either give me the same reading for all trannies or always measure half voltage whether a trannie is connected or not.
I tried the runoff groove tester for Vp and it seems to give each one a slightly different reading but the trannie gets really hot, really quickly.
http://runoffgroove.com/fetzertech10.png
I have seen a lot of folks over the years that have issues with the geofex one and the solution is usually just to build the similar one at runoff groove.
Also, I just have a cheap digital multimeter. Trying to match J113's
What am I doing wrong? Any tips or tricks?
I built my own jfet tester years and years ago, and if I remember right, getting the transistor pinout right is very integral. Could you maybe show your setup to us with a picture, including the design you're using, and then let us help verify you have the jfet pins correct?
Aentons
#2
Sorry, It's bit messy. Bottom is the one from runoffgroove. The j113 datasheet says the source and drain are interchangable
Aentons
I re-did it to be a little cleaner and using the nom-nom schematic.
I'm using a one spot outputting 9.45v.
With no trannie loaded I'm getting a reading -3.69v.
Aentons
I re-did it again with power on just one side and the source and drain swaped. Getting +3.9 with the trannie and -3.72 without.
I can't quite see that there's an issue. The thing I would suggest is maybe trying my version out. I know it works, and I've attached.
The other thing might be that your JFets might be fake, which is why you're not getting good readings.
Aentons
Quote from: jkokura on December 31, 2020, 10:34:41 PM
Thanks, I'll try yours. All the JFets came recently from Mouser.
Aentons
Nope, same result. I tried wiring it a couple of different ways. I tried a new opamp this time also.
Aentons
#8
The Arrow datasheet is newer (2020) and has the J113 pins listed as GSD. This is what I was using.
https://static6.arrow.com/aropdfconversion/ef7ceb2eaee61dd6eec61a61475125d8ab985b66/mmbfj113-d.pdf
I actually bought 100 of them from Mouser so I took a look at their datasheet, which is from 2001, and it has them as DSG. Wtf
https://www.mouser.com/datasheet/2/308/J113-1120625.pdf
https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/J113/?qs=ljbEvF4DwONIvgQL%2FiOeMA%3D%3D
Mine all have a date code of A21
Aentons
I measured them using the diode setting and they do appear to be DSG so that's good to know for sure.
I bought another multimeter that is advertised as having a 10M ohm impedance and tested the other multimeter. It has 1M ohm impedance, which I thought might be a factor causing the trouble.
I connected the new multimeter and initially got a -0.6v reading. Great! But then, I disconnected my leads and then reconnected, and now it back to about 3.8v. not sure what the deal is...
Measure the jfets using the dc voltage setting, that's what I do.
Aentons
Quote from: jimilee on January 01, 2021, 11:58:01 PM
I have been using the dc volt setting for the matcher circuit. I was just using the diode setting to verify which pinout the j113 uses because of the datasheets that seem to conflict
Ah. I should read more closely. And you're powering the jfet matcher of course? Do mind attaching some pictures of your set up?
Aentons
Here are new pics of a new rebuild using the new multimeter and a TL071 and a new battery.
Trannie inserted or not it reads -3.9v. What am I doing wrong?
Nothing, that sounds accurate, does another one read about the same?
