Aion Corona (OD1)
Started by mattc, October 22, 2020, 02:51:59 PM
mattc
I built the Aion corona over the weekend. It sounds really good with the stock clipping diode's. I tried some 1n60 germanium diode's in the second position. I really did not like how they sound. They're just a little bland in the circuit. For anyone else that has built the circuit, what diode's did you find worked well as an alternative?
Caedarn
#1
This might not answer your question, depending on what you think of as "worked well as an alternative", but I built the Corona with the "Tubescreamer" diodes in the second position.  I had done some reading on the history of Tubescreamers and the OD-1 and thought it would be interesting to compare them (sort of) in the same pedal.
Honestly, I haven't done too much playing around with it, but that was the theory anyway  :)
