Total Recall
Started by Rayzorxbass, August 29, 2020, 12:40:03 AM
Rayzorxbass
Hello all!
I'm new to the forum, and I'm interested building the Total Recall pedal.  Curious to get insights and tips from others here that have built this pedal.  Especially what BBD chips sound authentic, and any other tips you can offer.
Thanks!
Ryayzorxbass
One hint to start with: it's not an easy beginners build and reading the build doc three times will be essential.
Rayzorxbass
Quote from: cooder on August 29, 2020, 05:07:55 AM
Thanks!  I'm not a beginner with electronics but I apprecate the the advice.  I'll definitely read the build docs thoughly.
thomasha
Actually, read everything you can find about the DMM, and how to bias it correctly. That is, IMHO, the most difficult part.
It may work, but you don't want it to distort, but you also don't want to have a volume drop after the pedal, so, you will have to adjust it again and again. Having read several biasing guides helps.
This^^^^ Don't forget about the BP cap. It will never work if you don't use it and in the right place. Don't ask me how I know.
Go slow, populate the resistors first, then take a break of about an hour or so. You'll avoid mistakes this way. After you get through with the resistors, go back and check out your solder joints and reflow where needed.  If you will go slow and methodically, your like will be great.
Stomptown
The Xvive MN3005s sound great.  I wouldn't hesitate to use them.  They are half the cost of the originals and you don't have to deal with potential headache of fake/DOA BBDs.
Who has some right now. I'm having a little bit of an issue procuring some.
Edit: found some at synthcube for 15 each.
Rayzorxbass
Quote from: jimilee on August 29, 2020, 04:22:39 PM
You're referring to a "non-polarized cap" right?
Stomptown
Quote from: jimilee on August 29, 2020, 05:51:55 PM
Nice find!
Rayzorxbass
Quote from: Stomptown on August 30, 2020, 07:43:57 AM
I just checked Synthcube and the Xvive's are listed as "out of stock".  They do have original MN3005 chips for $49 each.
I just pre-ordered some of the Xvive 3005 chips from cabintechglobal.com.  2 or more are $17.54 each.  They should be in stock on or before September 14.
Quote from: Rayzorxbass on August 31, 2020, 07:47:32 PM
Yep, they go quick.
