Smoothie 2020: vibe mod on a toggle switch?
Started by sjaustin, July 20, 2020, 12:50:06 AM
sjaustin
I'd like to do the "Univibe" mod on a toggle switch, but I'm not totally sure what to do. The instructions say:
Quote• There are two pads outlined next to Q2. You can ignore these. I had intended this to be a mod for a "Univibe" switch but in my haste to complete the layout I accidentally attached them to the wrong cap. D'oh!
• If you want to do the Univibe mod make C2 10n and C3 100n.
Would I have to wire one switch to toggle both of those caps between these Univibe values and the stock values? Having trouble picturing how to do that.
For a Univibe mod you want to have the phase stages at a 10:1 ratio. So, C2 and C3 need to be 10:1. Or 1:10. It doesn't matter which order it's in. When I put those extra pads in I was blazing through the design and didn't realize until later I put them on the wrong caps!
The easiest way to achieve the mod on the Smoothie is to switch out C2 for a 4n7. Or, you could toggle b/w 4n7 and 47n using a mini SPDT switch.
sjaustin
Quote from: madbean on July 20, 2020, 01:04:38 AM
Ah, so when the two caps are the same value, the effect acts like a phaser, and when they're 10:1, the effect acts like the vibe—so toggling one of them between equal and 10x (or .1x) is the way to have access to both sounds. I think that makes sense.
Wouldn't I need a DPDT, though? One cap on each end, with the common row wired to the PCB? BTW, I'm putting this in a multi-effect box, so space is not a concern.
No, you only need an SPDT.
There are actually three different ways you can do the switch mod but this one is the more common, I think. The two 2M2 resistors are only if the switch pops when you toggle it (they help keep all the switch contacts at approximately the same voltage levels).
