G3 on Aristocrat V.4
Started by MattL, November 26, 2011, 10:56:08 PM
MattL
Since I only have a wiring diagram for the one sided version of the Aristocrat, and can't find a third ground on the one sided, I was wondering if G3 is necessary on the two sided version, and if so where would it go to? I guess if I had to guess I'd maybe say the sleeve of the input jack? Also, on the one sided is that jumper below R13...I don't see it on the two sided, so I'm assuming that's otherwise covered...it looks connected at the bottom of the board. Thanks, Matt
bigmufffuzzwizz
If you have a multimeter you can check to see if it's connected to all the other ground pads. If it is then it's there for your convenience.
MattL
Oh, okay, thanks...guess it just makes for less clutter when you would otherwise try to fit several grounds on one lug, as in the star grounding procedure.
