Id'ing transistors from within a set
Started by Philthy, June 22, 2020, 12:11:41 AM
Philthy
Hi,
I have a tonebender "set" of ac125s (or ac128s - can't remember which)  that I have mixed up such that I now no longer know which is Q1, Q2 or Q3.
Is there a way I can ID them using a basic multimeter with no Hfe/leakage capability?
THanks
ahiddentableau
Hopefully this meets your "simple" requirement, but you can (and should) build this:
https://tagboardeffects.blogspot.com/2012/08/germanium-transistor-tester.html
Very easy build and it works great.
There is an RG Keen article that explains it that should be easy enough to find via Google.  [EDIT: it's linked on the page given above]  RG Keen...is there anything the man can't do?
Philthy
