Pig Butt - 1st Pedal Build
Started by JamesMc, June 01, 2020, 02:42:16 AM
JamesMc
This is my very first build.  Honest critiques would be greatly appreciated.
Already know I don't like the greenies...
Thanks for looking.
That can't be your FIRST build. That looks like your 20th build. Very clean solder joints, especially on switches which can easily have gaps since the holes are large. Clever placement of the LED.
That looks great.
Quote from: lars on June 01, 2020, 03:45:11 AM
That looks great.
What he said.... Noice!
Seriously, my first build was a rats nest of wires, tilted components, big splashes of brown flux, and... a non-working circuit. (Not to mention a plain metal enclosure of course)
Very very well done!
Nice one dude, creative graphic...made me smile :)
Hexjibber
That is a really quite excellent first build, inside and out! Really impressive! Keep it up!
rockola
Great job, wish my first effort had been half as swish.
That is indeed a very fine quality build.
The only critique I could possibly offer would be regarding the reliability of your shielding.  That box has a lot of paint, and it looks like the threaded bushings of the jacks are the only available ground connections to the enclosure.  This will probably be fine most of the time, but it could be possible to tighten the jacks so that the threads fail to contact the metal of the enclosure. I recommend grinding away a bit of paint from the inside wall around one of the jacks so the jack shoulder can contact the enclosure as well (just need to do this with one of the jacks).
Depending on your pedal board setup, you may want to ensure electrical continuity between the lid and the main body of the enclosure as well so that you would have proper shielding underneath the pedal.  This is generally much less important, however.
So, that's your first build and you went back after your tenth build and cleaned it up, or this is the only finished pedal you've ever built?
My first build looked more like a$$ than butt.
Very clever graphic and super nice build.
JamesMc
Thanks to everyone for the encouraging words.  Honestly, this is my very first ever pedal.  Definitely not my last.
I have completed another one since this one, but it is not an mbp board.  I have another mbp board I'm working on, but waiting on parts.
Thanks EBK for the tip.  I use powder coated enclosures as of now, because I suck at painting.  Will go back and grind off some of the paint, just to be safe.
Quote from: JamesMc on June 01, 2020, 02:45:32 PM
You win, my soldering iron isn't worthy! I'm very impressed.
MTK
That easily looks like a 10th build. Great work.
great build and I love the labelling, graphics and choice of enclosure colour. well done!
Philthy
