Tips For Desoldering Components
Started by FuzzMonkey, April 29, 2020, 05:49:24 AM
Quote from: Aentons on May 01, 2020, 03:22:32 AM
Quote from: pickdropper on April 30, 2020, 09:48:10 PM
I'm a big fan of soldering blades.  The one I have can heat all three legs of a 16mm pot at the same time.
I'll have to try one of those! Seems like you could burn a chip real quick with that thing if you are not careful. Do you use it when you are trying to reuse a part?
For me, it's more about trying to get the part cleanly off the board.  It allows me to hit multiple pads at the same time.  I generally use it more for pots and passives than anything else.  As far as burning parts, it's basically just a big soldering iron so normal dwell time rules apply.  Make sure to have plenty of solder on the blade tip and it goes faster.
For DIP ICs, it doesn't work as well as you really need to heat both sides of the IC at the same time.  For that, I still use blades, but dual blades on soldering tweezers, like this one:
I have an old Hakko desoldering gun I got from CultureJam, but I rarely use it.  I have better luck with these.  Opinions vary, so somebody else might feel exactly the opposite.
Quote from: pickdropper on May 01, 2020, 11:43:43 AM
soldering tweezers
8)!
I must remember that those exist.  Just seeing the pic made me marginally happier in these dark times.
I would really like to see an array of soldering blades with a shaver handle though. Lift and desolder in a single stroke!  ;D
Quote from: EBK on May 01, 2020, 12:35:56 PM
soldering tweezers
8)!
Desoldering tweezers are magical.  The blades actually get the least amount of use.  I usually use the pointed tips.  Wonderful for pulling two-legged passives.
Funny I was thinking not too long ago about trying to make a tool like the desoldering bar. I tried to kludge one together using buss wire but it failed hard.
Aentons
soldering tweezers
8)!
For some reason those seem like an April fool's joke. I wonder if you could ductape a couple of irons together...
skyled
Quote from: FuzzMonkey on May 01, 2020, 03:03:18 AM
Quote from: skyled on May 01, 2020, 12:26:53 AM
I have a desoldering gun with a vacuum pump on it. The thing is magic.
Pic, please. ;)
I think it's this exact model, but I only paid like $90 on ebay. Make sure you get one that's the right voltage though! Lots of ebay ones are set up for Chinese mains power.
https://www.amazon.com/Aoyue-Contained-Desoldering-Internal-Carrying/dp/B00PGFAJWS
FuzzMonkey
QuoteI think it's this exact model, but I only paid like $90 on ebay. Make sure you get one that's the right voltage though! Lots of ebay ones are set up for Chinese mains power.
Thanks. I've seen the Hakko FR-301 but they're really pricey. Is there much maintenance/cleaning required after use?
skyled
The only maintenance required is that after enough use you gotta clean the sucked up solder bits out of that cone-shaped spring. I rarely have to use it these days, and I've only cleaned it maybe 2-3 times in ~10 years.
FuzzMonkey
Quote from: skyled on May 10, 2020, 05:41:23 AM
I'm based in New Zealand, so will see if they make a 240-volt version.
So, about those desoldering needles - 100% crap. Threw them away. Better off with a toothpick or dental pick.
FuzzMonkey
Quote from: jubal81 on May 25, 2020, 06:13:09 PM
Good to know.
