Rangemaster Mod
Started by igore42, November 20, 2011, 03:32:46 AM
igore42
Hello,
I've built the Rangemaster pedal from a PCB I bought here at MB.  I wanted to mod it to switch between normal operation and just boost with no input filter caps.  Attached is my proposed diagram, can any of you "veteran" builders comment if this will work as I intend it too?
Thanks,
Doug
There's a simpler way to do it if you'd like.
Instead of using a T/M switch, you could make that switch bypass the input capacitor. Find what input cap value you want by using sockets for C1, and then for C2 you could jumper it. Then, when you use the switch in the on position it will bypass the tone cap.
Otherwise, your mod would work.
jacob
