jmk test rig
Started by Thewintersoldier, February 01, 2020, 01:49:44 PM
decided that I had outgrown my old test rig and wanted a more streamlined all in one more flexible solution. Built the jmk testing rig and added a variable voltage ala madbean test rig via a road rage board I had.I decided to cram 10 pounds of shit in a 5 pound bag and stuff it all in a 1590bb box. the only road rage i had was a bypass board so that made it a tighter fit. added a 12v tap wired off the 15v with a 12v regulator wired in series. love this thing. sharpie labeling ftw!
old box:
new rig:
dawson
That's awesome, man!
It may just end up being your most-used pedal!
Criticism is encouraged: constructive, or otherwise.
woolie
Quote from: Thewintersoldier on February 01, 2020, 01:49:44 PM
old box:
new rig:
I'd love to build this. Do you have plans or instructions?
W.
Sent from my iPad using Tapatalk Pro
Quote from: woolie on February 01, 2020, 07:30:54 PM
old box:
new rig:
W.
Jmkpcbs.com or did you mean the charge pump?
That's pretty awesome yo. Just keep in mind that a charge pump isn't regulated. You would need a regulator, but I don't know how to do that.
The 12 and 15 volt taps are regulated because they use regulators. 18 volts is unregulated. But for simple testing and biasing before boxing it shouldn't be an issue.
Quote from: jimilee on February 01, 2020, 07:55:29 PM
The test rig is from jmkpcbs.com and the voltage selector is the madbean road rage board. All instructions are in the build docs for each pcb. I just painted by numbers haha
old box:
new rig:
W.
woolie
Sounds about my speed. Thanks, ordered.
