Help me Mr Bean, you’re my only hope
Started by jimilee, January 28, 2020, 10:40:06 PM
My Aquaboy is way different than the BOM. There are spots in the board for which there are no numbers on the BOM and pets are moved around. R30 for example. On the board it's above where it says aquaboy and on the build doc, r30 is to the left of IC2. My C34 and 35 are where C31 and 32 are on the build doc.
Jimi, I think you have a prototype Aquaboy board. Maybe I gave it to you quite a while back? In fact, I am sure of it. It's green right?
I can get you the correct info for the board you have.
Yep, it's been sometime.  I got the resistors  mostly populated, so I'll have to remove them and start again. Doh!
